Now that is a very good point about high pressure for the rear tyres. I was not paying sufficient attention to the numbers when I looked in the book. The odd thing is, I got those numbers from a U.S. Farmall M Owners Manual.
By comparison, the Farmall AM Owner's Manual says:
For Front Tyre 6.00-16 at 6 ply 36 lbs maximum.
For Rear Tyre 13.5-32 at 6 ply 20 lbs maximum.
For Rear Tyre 11.0-38 at 6 ply 20 lbs maximum.
The Farmall Super AM Owner's Manual says:
Front 6.00-16 at 6 ply 36 lbs maximum.
Rear 12.0-38 at 6 play 12 lbs minimum & 20 lbs maximum.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
