jal-SD has a good rule of thumb for the rear tires. For example, the SC came out with 10X36 tires. IH recommended a minimum of 12 psig (10+2) for 4 and 6 ply tires. When plowing the tire on the furrow wheel was to be increased by 4psig. The front tires, 4 ply were to have 28psig. For 6ply the pressure was to be 36psig.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
