I use a "rule of thumb" of a pound per inch of rear tire width plus two pounds. If you have a 12.4 X 38 or 36 inch rear tire, I would put about 14 or 15 pounds of pressure in it, depending on how the sidewalls look. If you have a 11.2 X 38 or 36, I would use about 13 or 14 PSI. Same for 24 inch rims. (My $0.02 worth. jal-SD)
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
