Re: Front and Rear Tire Pressures
Posted by Harold Evans on April 22, 2012 at 17:06:46 from (98.220.4.76):
In Reply to: Front and Rear Tire Pressures posted by Dave Miller on April 22, 2012 at 16:32:35:
Check out this site for a Farmall H. Your other tractors may take different pressures, but this is a start:
http://pages.suddenlink.net/twcook/farmall-h/afteryoubuy.htm
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
