Posted by jimb2 on April 22, 2012 at 16:00:43 from (174.115.9.174):
In Reply to: International 444 Gas posted by metalmender on April 22, 2012 at 06:49:38:
Hi Metalmender, I have never changed a clutch in a 444 although in the past we owned B414D, 434 and 384 Diesels which all have the same clutches/transmission as your 444. I have adjusted the PTO clutch through the inspection plate at the bottom of bell housing. The more difficult part of 444 is there are two clutches PTO and transmission and there is a gap setting for the the throwout fingers. USING proper SPLITTING STANDS, I have changed clutches on 74 series tractors and I always mount clutch and pressure plate on the PTO and transmission shafts, then put long bolts in the bolt holes as guide pin and that will guide the transmission shaft into the pilot bearing hole. Put some lube in pilot bearing hole. NEVER FORCE the two halves together. If it doesn't go together with just a little force, something is not aligned properly. Next remove the starter and use a pry bar in the flywheel teeth to turn the engine to align the flywheel and pressure plate bolt holes so the bolts can be installed through the inspect plate hole. Then do another revolution of fly wheel and torque bolts to proper spec. The finger adjustment can be done through the inspect hole as well.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
