Re: Faint white smoke.
Posted by IH fan on April 20, 2012 at 09:39:15 from (108.236.93.48):
In Reply to: Faint white smoke. posted by Janicholson on April 19, 2012 at 21:26:24:
If it's water or coolant, it should not be visable after a few seconds. If it keeps it up, oil is blue or white and fuel is black.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
