Posted by jwag on April 20, 2012 at 00:22:49 from (192.249.47.178):
In Reply to: Faint white smoke. posted by Mr Farmall on April 19, 2012 at 21:26:24:
I see no issue here. The burning of gas results in combustion byproducts that include water vapor. If you are not using/losing coolant, have no indication of head gasket leak, I"m thinking that your IH muffler is cooling the exhaust down to a temperature where the water moisture from combustion condenses and shows as vapor. I would venture that this is the least important thing to worry about in your life.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
