Posted by El Toro on April 08, 2012 at 16:45:13 from (108.3.225.57):
In Reply to: farmall 230 posted by tom grim on April 08, 2012 at 16:29:35:
Your ignition switch may be the problem. Locate the wire that feeds battery voltage to your coil on your switch. Pull that wire off the switch when the engine is at an idle and see if the engine stops. Alternators can cause voltage back feeding causing the engine to keep running. Your switch may not have a good ground. Hal
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
