Check to see if you have spark. Do you have a coil or mag ? Does it fire at all ? Wouldn't be a bad idea to pull off the valve cover to make sure all the valves are unstuck before you bend rods, pour oil on them too. Don't be cranking an engine that has sat for a long period of time for long since the bearings won't have much oil, if any in them.
If you have spark, the next step is the carb, is it getting fuel? there is a screen in there, as well as in the shut off bowl. You can take the fuel line off the carb to see if there is flow or not.
You didn't mention doing anything to the carb, I would take it all apart and clean it if you haven't already.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
