To the best of my knowledge, and after looking at the parts list there isn't one. The metal of the pedal (excuse the pun like words) Is in contact with the brake pedal cross shaft. To repair it is rebushed locally to the shaft size. If the shaft is worn, the solutions are to turn the shaft down to a just less than the wear, then ream the new fabricated bushing to .0015 to .002" bigger. The other way is to remove the shaft and have it welded back to size and turned/ground to original diameter, then use a bushing to the same spec as above. Be sure to drill for the grease Zerk. Jim
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
