Posted by charlieu on March 13, 2012 at 20:04:31 from (209.131.230.214):
In Reply to: 350 center housing ? posted by riverbend on March 13, 2012 at 18:10:41:
I know that all the bolts that hold the rear split are 5/8 inch in Dia. One question, did you remove the bottom center bolt? That's the bolt that is under (maybe I should say above) the small cover on the bottom of the TA housing. You said that you have removed 9 bolts I can not remember how many bolts there are for sure. I have a TA housing setting on my transmission stand at my shop that I will count in the morning. I'm planning on making it into a cutaway model for RPRU this summer.
The rear split can be fun to break loose if the last time the two sections were apart and somebody used some gasket sealer that is really holding it together. Good Luck Charlie
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
