llamraf,"Burn it out"... Since you have the engine torn down you are already 2/3 of the way home..... Remove fuel tank if its not all ready off, roll tractor out side , make sure all Flammable items are clear of the area. ! Fill the cylinder with the most volume! up with Diesel, add a splash of gas, set it on fire, drink a cup of coffee as it burns, when it has burned itself out drive the piston out from the bottom. the burn time or # of burning will vary from 1 time if the piston is at the bottom of the stroke, to quite a few if the piston is more TDC. This method will get a engine loose in 1 afternoon! Just use all fire precautions possible, do not burn your shop down! Later, John A.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
