remove spark plugs, take compressed air and blow everything out of cylinders. most likely water on top of piston, so penetrant cannot get to rust. add penetrant and start over. failing that remove oil pan and head.
i put a jack under rod bearing and raised front of tractor off the ground, then used screwdriver in flywheel, before engine came loose. engine runs fine.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
