Posted by rustyfarmall on February 10, 2012 at 07:35:45 from (216.248.71.224):
In Reply to: Question on the E85 posted by sflem849 on February 09, 2012 at 21:01:06:
For what it's worth, I also own a 1950 H that is pretty much all original. I've never had the head off, and the carburetor has never been touched as far as I know. I tried running it on the E85, but it seemed the slow warm up time and throttle hesitation issues were several times multiplied, so I went back to the E10. I'm sure I could make it run on E85, but it might take a bit more tinkering.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
