Posted by Chief 83 on February 05, 2012 at 06:58:09 from (24.21.76.219):
In Reply to: Cub transmission posted by Chief 83 on February 04, 2012 at 16:19:33:
I'm going to pull the shifter this morning. After thinking about it I may have broken the shift fork for 2/3. What I didn't mention in my first post was that I also replaced the shift knob. I boiled it first to get it hot since the fit is soooo tight. Then pushed it on with a bunch of force. I just might have damaged the shift fork doing it. We shall see. One step forward and about 3 back...
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
