Posted by CoopertownBob on February 03, 2012 at 09:24:24 from (74.51.5.124):
In Reply to: M not charging. posted by RTR on February 02, 2012 at 16:33:17:
It's not been covered yet so I'll offer it. Are you sure the battery will hold the charge? Test by charging over night on a charger, then leave it till the next day and check the voltage. If it takes AND holds charge, then there is a fault probably in the wiring.
My H would charge like made but not hold one in the battery all week, but off the tractor it held just fine. Turned out the wire going to the gauge was leaking voltage due to cracked insulation on it. Very tiny crack at that, actually had to take it off tractor and bend it to see it. Used a multimeter to ohm out all the wiring and finally noticed a difference in readings on that one wire from one test to the next. Replaced wire, problem solved.
Was glad that my Dad is a retired electrician!
This post was edited by CoopertownBob at 09:25:04 02/03/12.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
