Posted by soundguy on February 02, 2012 at 17:24:54 from (107.41.212.242):
In Reply to: M not charging. posted by Ellis Kinney on February 02, 2012 at 16:33:17:
i kinda just went down this path with my H.
came with a newish, non working junky chinese regulator.
I dinked with it and cleaned up the contacts and had to tweak them to make them strike correctly, and rigged up a tickle switch while waiting for parts...
I got one at napa that was worse.. and didn't work.
finally got one at car quest that works ok.
if you can ground the field and make the ammeter show charge.. it's simply a regualtor field circuit issue...
if that works.. get back with us.
if not, then pull the belt off and motor test the geny.. if it motors, then it should charge.
get back to us for a detailed set of tests to bypass the cutout and field..
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
