Posted by Pete_5959 on February 02, 2012 at 17:12:21 from (138.162.128.55):
In Reply to: M not charging. posted by Ellis Kinney on February 02, 2012 at 16:33:17:
Ellis, What battery are you using? 6, 8 or 12 volt? I went down the exact same path your are travelling now. The ground on the voltage regulator has got be be good. Janicholson also pointed me down the right trail in putting in a 6 V battery and removing the 8. H charges as it should now.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
