Posted by Janicholson on February 02, 2012 at 17:01:08 from (96.24.99.126):
In Reply to: M not charging. posted by Ellis Kinney on February 02, 2012 at 16:33:17:
Step one is to polarize the generator (not the regulator). This is done with the tractor off. with things connected as the diagram, use a piece of copper wire (#12 solid is good) and jump between the regulator Bat terminal and the Arm terminal for one second. This bypasses the regulator and will spark some. If it is still not charging, clean the mounting bracket and attachment of the regulator. It must be an excellent ground. If no charge, use that jumper wire to ground the field terminal on the gen. Run it at 3/4 throttle and see if it charges. If not make sure the gauge is working when the lights are on, or the Ign switch is pulled. If not, the gauge may be stuck. Get back to us with answers to these efforts Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
