Posted by glennster on February 02, 2012 at 16:58:45 from (99.90.9.153):
In Reply to: M not charging. posted by Ellis Kinney on February 02, 2012 at 16:33:17:
i fought with my h over charging issues. janicholson helped me figure it out. on the studs on the genny, there is a f terminal and the a terminal. the insulation was cracked around one of the terminals, and then it was put on the tractor and tightened up, it would ground out and not charge. cant remember the whole proceedure, but you would isolate the brushes with slips of paper than use a continunity tester between the posts on the terminals and the chassis of the genny. maybe jim will jump in on this and explain it better.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
