The most likely cause for you problem is hardening of the O-ring seal between the center section and the rear frame.
The oil passage between the filter and the MCV pump goes above the normal oil level where the two housings join together. With age the O-ring will harden and take a set so that it will not seal properly. Air enters the suction side of the pump and as the pump starts to get worn it no longer is as efficient at pumping air as a new one. Adding enough oil to ensure that this O-ring is below the oil level will keep air from entering the suction side of the pump and the symptoms will disappear.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
