Re: Farmall H with Sickle Mower
Posted by dhermesc on January 25, 2012 at 16:07:57 from (24.248.193.103):
In Reply to: Farmall H with Sickle Mower posted by pgarrett on January 25, 2012 at 12:53:21:
What does the mower look like? Does it have a wooden pitman stick or a long belt with a big steel wobble box (balanced head mower)?
A working balanced head mower could easily be worth $350 to $600 or more in the right place.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
