International or Farmall makes some difference. i'm not familiar with the non 3 point models but my guess is there is only one pump inside the center housing that feeds the power steering and then the remotes. The first step should be a pressure gauge plugged into the quick coupler(s). A good guess would be the priority valve that allows fulltime power steering pressure is malfunctioning. It's also possible the relief valve for the remote valves is stuck open or just broken. if you have more than one remote pair, make sure you have the correct combination of hoses paired to the couplers and then see if the behavior is only with one valve or if it is on all of them. look for check valves or restrictor valves between the cylinder and the couplers that could be screwed up too.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
