Posted by rustred on January 19, 2012 at 07:48:17 from (74.200.18.156):
In Reply to: super m stuck in gear posted by tpoplett on January 19, 2012 at 07:11:11:
remove the gearshift and line up the shifting rails with a cat bar or big screw driver,no big deal. this commonly happens as the gearshift end gets worn and needs rebuilding.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
