So many variations of culitvators it is hard to tell, but it looks about right for an HM-250. The fertilizer unit might be HM-53C, which was used with the 250 cultivator. If you have Guy Fay's data book, pull it out and look at the front cover. If you don't have it, look at it on Amazon.com.
If you decide there is too much missing or it isn't good enough to ever use again, I've been looking for the cylinder mounting brackets that bolt to the tractor frame rails.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
