Re: removing stubborn tires
Posted by mkirsch on December 22, 2011 at 13:15:32 from (64.80.110.74):
In Reply to: removing stubborn tires posted by riverbend on December 19, 2011 at 13:13:21:
48" farm jack.
The inner bead is easy. Just jack against the drawbar.
Outer bead is a 2-man job, and you need a chain to wrap around the drawbar.
Technique is VERY similar to the one shown on the Cub tire above. Same kind of jack too, only we call them "farm jacks."
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
