In case you don't have down pressure (I know a 350U does, not sure about a 350), my uncle used to break them loose by laying them flat on the ground and backing a rear tire up on top of the tire/wheel combination, onto the tire but as close as possible to the rim. If that didn't work, he would lower a 3-bottom plow onto the tire, with one of the points right next to the rim. I never saw that method fail.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
