Posted by FC Andy on December 12, 2011 at 15:29:05 from (74.126.84.52):
In Reply to: push pull switch 706 posted by crystal allis on December 12, 2011 at 13:14:16:
From the 450 series and up they should have the same Key. Now, I'm not trying to be a smart A$$, but the way I read your post, the engine is shutting down, which has nothing to do with the key switch/ push pull switch. Now, if only the electrical is going on and off, you may have the culprit. Dose it make a difference if you jiggle the switch? And- I once had gauge lights that I could not make work. Nothing made sense. Turns out, the multi-connecter behind the fuel tank and ahead of the steering column had corroded the connections. Took it apart, sprayed some battery terminal cleaner in there, waited a few minutes, blew it out, plugged it back together, and Viola! The gauge lights worked, and, Ignition power worked better, too. Less fussy on key position. Just a thought. -Andy
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
