I don't think the points for this model have been available for quite a while. If you plan to do any serious plowing you will need to replace the plows with the Super Chief setup. My dad wore out a set like this and was forced to replace the plows in the late 60's. The new Super Chief used a standard one piece plow share. Your points look like they will do some plowing before needing to be replaced.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
