3-14s FH (I dont have the Model # but We have one! It is a mounted trip plow in the sense that all 3 can trip at once and keep from stopping the tractor (except under a 6 inch lateral root Dont ask what a gas cap tastes like on a 350U) The gauge wheel on ours is rubber implement tire, not steel. The coulter is called a Lantz Coulter (or a knockoff of that. It flips the top edge of the sod and ground trash over to allow better coverage, and less hangup in the beams. I think the first moldboard is tweaked out of alignment. The style of bottom is called Plow Chief. It has removable points and separate shares. They plow well and are Reliable. Points and shares might be difficult to find, but I have not looked for them at all. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
