Posted by D Slater on November 21, 2011 at 04:48:13 from (184.15.44.59):
In Reply to: MD split/engine swap posted by hatrick on November 20, 2011 at 18:35:44:
For saftey when supporting the engine like the picture always use dowel pins and then at least one set of bolts in frame rails to back plate when sliding apart. Do not remove frame rail to back plate support unless engine is supported from above or other. Front engine mount is a slip fit on the front engine cover and can let the engine fall at least down in the frame rails if frame rails are not supported to rear plate or in other ways. Good luck
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
