A fouled plug is usually caused by a low compression cylinder or the wrong heat range plug. If a D-15 was recommended that's not to say a D-21 might work better. I don't think the QC at Champion is as good as Autolite. I do know that the discount auto stores do buy plugs less than first line. If those Champions are less expensive at ABC Discount Auto Parts than they are from say NAPA there's a good reason.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
