Posted by CNKS on November 12, 2011 at 13:31:40 from (216.144.104.128):
In Reply to: H oil level posted by Tim (UPS) Johnson on November 11, 2011 at 16:55:07:
Use 6 quarts. BUT, the fill level to the upper petcock is 5 quarts. I did the same as you did on my Super H and initially thought that hyd fluid had leaked past the hyd pump seal. That was not the case. The extra quart is for the filter, it drains into the pan when the engine is stopped. that said you can simply keep it at the top petcock when the engine is cold and you are ok.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
