Posted by Tim (UPS) Johnson on November 11, 2011 at 19:50:47 from (208.126.186.71):
In Reply to: H oil level posted by Tim (UPS) Johnson on November 11, 2011 at 16:55:07:
the oil canister was full when i changed the oil.cracking the canister when engine is running does produce oil,but when shut down it does drain back,i guess my biggest question is why does it show so far overfull with the required 6 qts? thanks Tim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
