Posted by Owen Aaland on November 11, 2011 at 19:37:38 from (216.47.32.147):
In Reply to: H oil level posted by Tim (UPS) Johnson on November 11, 2011 at 16:55:07:
The oil never stays in the filter on an H. It has a bypass filter, not a full flow system. Oil enters the filter through the small hole in the center bolt and drains back to the pan through the open drain hole. The drain hole is much larger than the orifice hole in the center bolt. Unless the copper gasket leaks under the center bolt the top of the oil canister never fills with oil because of the air trapped in there.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
