Posted by Paul from MI on November 11, 2011 at 18:38:05 from (204.106.241.145):
In Reply to: H oil level posted by Tim (UPS) Johnson on November 11, 2011 at 16:55:07:
Was there oil in the filter housing when you changed it? If not, maybe the oil passage to the filter housing is plugged? If you crack the oil filter cover while the engine is running, does oil run out? If so, the oil is getting to the filter, next check the drain back toi the crankcase. Just some thoughts. Good luck, Paul
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
