Posted by Nebraska Cowman on November 07, 2011 at 04:58:44 from (66.252.115.26):
In Reply to: Poor luck continues posted by Chief 83 on November 06, 2011 at 16:58:25:
here's how to check a coil. disconnect the wires (you can do this with the coil off and in your hand) have the high tension wire in the tower. Hook a battery (or battery charger) positive to + and then touch the negative to the - side. When you release the connection it should throw a spark. What you are doing is replicating what the points do.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
