All I can tell you is that I have a 464 diesel (almost the same tractor), and the hour meter is broken at 15,299. It has been that way for many years! There has never been any engine, clutch, transmission, or hydraulic work done on it that I know of. We did overhaul the injector pump and alternator this year. It cost $600. It is an incredibly solid tractor. It will run and run and run. The 464 has done its share of plowing (3-16 in 3rd gear), but now we mostly cut and bale 14 acres of hay per year with it. It gets 50-100 hours per year, and it cranks up great even in cold weather. Fuel economy is INCREDIBLE! Not even 2 gallons an hour pulling a JD 336 baler! If I were you, I would buy the tractor if you need it.
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
