Some things to try when it doesn't start. If sure the battery cables and connections are okay and you have the original type starter switch on top of the starter. Test to see if power is on the small terminal when switch is turned to start. Or making sure the tractor is out of gear, jump power from the battery cable terminal to the small one. If that doesnt crank it run a jumper cable from positive or starter battery cable to starter post or strap going to the post, this would bypass the starter switch. Small terminal no power = bad ignition switch or a bad connection from or to the switches. Bypass starter switch and starter works = bad starter switch. Jumper cables from positive battery terminal to starter post and the negative to good ground = bad starter or bad battery. If tractor has a later type starter switch with 2 small terminals the small terminal with a S will energize the switch.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
