Hi...I also have a Farmalll 340 that was converted to 12 volts with negative ground. I have not been able to get the gas gauge to work. The 340 tractor was originally 6 volts with positive ground. The positive ground issue seems to be a problem for the gauge. My gauge works fine when I test it off the tractor with a separate 6 volt positive ground circuit. But it won"t work with negative ground regardless of how I switch the wires around. The gauge itself seems to be built just for positive ground polarity. The other thing you need to be aware of is that the sending unit is actually a 6 volt variable resistor and if you give it 12 volts it will burn out. Not a good thing to burn up a resistor inside a gas tank. So, you definitely want to add a resistor to supply just 6 volts, but the polarity issue would still need to be solved somehow. Pete
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
