Posted by Janicholson on October 27, 2011 at 17:00:44 from (67.72.98.45):
In Reply to: H exhaust pipe. posted by davediehl@hotmail.com on October 26, 2011 at 21:37:31:
2.375 is the exact answer to your question. The pipe is threaded into the manifold and will probably be difficult to remove. It will likely not come out with a pipe wrench. Cutting them off flush with a sawsall, after poking a few shop rags down the pipe to prevent any rust or saw filings from getting into the cylinders will be a start. Then with that sawsall, cut notches into the inside of the remaining pipe (but not into the manifold (will take some looking carefully to be sure)) in 2 places spaced about 1/4 inch apart. Use a exhaust pipe chisel to peel the chunk between the cuts into the center, hammer such that the chisel curls it shearing the two cuts leaving a cleaned chunk of thread. Now the remainder is easy to force into the center and remove with the muffler chisel. Next find a rental store to loan you a 2" NPT threading Tap. (do not think of purchasing one unless you are well funded!!!) A friend in plumbing may have access to one! Use it to chase the threads and get old rust out so the new shiny pipe from Wardner etal. will be in a good home. Put silver moly anti sieze on the threads. Use a magnet to remove most of the trash in the hole, then remove the rags being careful to not loose material out of them (starting the engine to blow them out might be entertaining, and provide certainty that no particles were sucked in!) Jim
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
