Posted by D Slater on October 26, 2011 at 06:26:39 from (184.15.3.93):
In Reply to: 450/M Interchangeability posted by Clifford McKinney on October 26, 2011 at 05:42:29:
Those gas and LP engine parts will interchange.
Only thing is a original SM camshaft was a little lower on the power output than a 450. Also two different ways of retaining the cam gear to cam were used on a 450. Left hand threads and right hand threads. there is a engine serial # break. If you get a used cam get the nut with it if different than yours. If using the right hand thread cam a 400 is the same. Some places will grind your old cam lobes and suface the lifters. Also maybe this site and other aftermarket places sell new cams and gears for that engine. If getting a used cam gear most will have a number on them and a suffix. M through 450 will have the same # but different suffix. Get one with a DB suffix used on part of the 400 and all 450.
Replacement parts installed over the years make finding any of the non original parts or parts you want in any M to 450 tractor a maybe. Only way to know for sure is check inside.
Also now any new parts you want will probably be the same for a M to 450.
This post was edited by D Slater at 06:35:05 10/26/11.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
