You don't adjust point gaps on voltgage regulators as the points are always closed when not running. You can adjust the armature air gap but that is not necessary unless you have had them apart. You adjust spring tension on hanger to change voltage settings. The cut out portion of the regulator does have points that are open but they do not affect the charging voltage, only cut in and out readings. And, normal running voltage on 12 volts system is above 12.8 to 14- 14.5. with the lower reading being a low battery taking a heavy charge and high reading being full charged good battery. Better not to mess with it until you know you have a problem.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
