Since the input shaft on the hydro is supported on two tapered roller bearings it has very little room for any movement and no pilot bearing is used on the end of the shaft in flywheel. What shape were the pump vanes, did it bust them up and wedge in there causing the problem or were the bearings loose. It is quite a procedure to adjust the end play on those bearings. I used to actually do it before I mounted the hydrostatic pump on shaft and then you can tell what you have with out spring pressure against them.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
