If the capacitor in the alternator is bad it can cause a sensitive digital voltmeter to give widely varying readings. The regulator is either sending full field current through the rotor windings or no current through them. As a result the alternator output is either nothing or maximum voltage. The amount of time the field current is on compared to the time it is off is what determines the average output voltage. The capacitor in the alternator helps to even out the voltage output. Generally the higher the quality of the digital voltmeter the more times per second the voltage is checked and displayed on the screen which results in ever changing numbers. If your meter does not have some capacitance built in when checking voltage the numbers can always be changing. An analog meter simply can not react fast enough to these voltage changes and so the reading is steady. Simply adding a capacitor between the leads of your meter when checking the battery voltage with the alternator charging should make the results readable.
A simple cure for an ammeter that pegs out after converting to an alternator is to run a small wire between the two terminals on the back of the meter. It then becomes a shunted meter and will show amps based on the resistance ratio of the meter and the shunt wire. If you use a wire with the same resistance as the meter the amps shown on the meter will be half of the total amps flowing in the circuit.
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
