The most likely reason the amp meter was bypassed like that is due to the fact the alternator puts out a lot more amperage than the original amp meter was designed for. Gives you a direct connection from alternator to battery. I have wired several alternators over the years using original ammeter and got by most of the time. I just recently put a ammeter for a 66 series IH tractor in my own M to have a high capacity ammeter. It will charge just fine without an ammeter but you cannot tell what it is doing. Some install a voltmeter instead which works well. Only thing is , not many operators know how to interpret a volt meter reading. It will be showing 14 volts for example and everything is normal but operator thinks it is charging full blast when in reality it may be charging only a couple of amps as battery is full charge. On the other hand it cold be showing those same 14 volts and battery taking a moderate charge. When battery is low, voltage will be somewhat lower at same time heavy amperage may be flowing. Confused, well. You have to understand how a battery and electricity function to not be. But, in reality you don't really need to know all about it . Leave that for the mechanics. Just know what is acceptable normal readings. Far as replacing wiring, that is your call. If in tough shape I would.
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
