Pull the plug wire on the cylinder that is closest to the noise. if the noise changes substantially, it is likely a wrist pin that is loose. The rod would need a new bushing pressed in, and fit to the old, or new wrist pin. The fit is .0005" max. if tighter but still will move by easy hand movement on the pin it is OK. Loose timing gears from the front pulley being improperly seated is another possibility if the noise does not change with the plug wire off. Loose cam gear is actually modestly common. Valve adjustment wrong (loose) is possible, as is a rocker arm moving sideways on its shaft. A worn valve guide also makes the same noise, Usuallt so worn that it can be moved sideways with the spring on it. Best of luck. Jim
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
