That screw is likely the whole issue. It will drain the carb because it is in gasoline. The screw adjusts the fine tuning of the power jet. If it is shut it will not have full power and run very badly. The initial setting is 3 to 4 complete turns out. From there adjust in until it starts to act like it did, then turn it out one turn. in heavy real work, it should be turned out till the muffler gasses are just a little black, then turned in till they clear up. Rubber hose is not as good as fuel injection hose with reinforcement for pressure. It has no pressure, but the fuel is under gravity feed and if it breaks or leaks seriously it will burn the tractor. The best is the original Steel line. Best of luck, it will be great. Jim
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
