The exact oil pressure is not the problem. It is a change from the normal pressure that is. A chevy six with dippers on rods had 14 psi max. An H farmall will run about 70 psi max. So, if the H only puts out 14 psi you have a problem, chevy six was fine. If you have the aluminum oil filter base I suspect the pressure relief valve is shot. Easy fix. They originally had a fiber wafer and it erodes and leaks pressure. Might be oil pump end plate if valve is good. After that, think bearings, but if it holds forty psi at higher speeds it will not cause a problem.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
