Posted by Janicholson on September 21, 2011 at 15:35:03 from (96.24.99.126):
In Reply to: 2606 won't start posted by bc on September 21, 2011 at 12:25:43:
The first issue is to determine if the timing is off. With the plugs out so it is easy to turn, put a test light on the lead to the side of the distributor from the coil. Turn on the ignition and turn the engine (pushing it in high gear works) until the first timing mark (in forward rotation) is at the pointer. The timing should now just cause the light to light or flicker as the points break. If the light stays out, look at the rotor and see where it is pointing. If toward a terminal, good, if not there are issues with timing. Rotate the engine till it does come on. then look at the pointer, if it is off 20 degrees or so the timing gears may have issues. Jim and
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
